Viewing the Results
View the results from the FSS element solution in POSTFEKO.
Plot the coefficients as a function of the plane wave theta and phi
angles.
Figure 1. Transmission / reflection coefficient versus plane wave
theta.
![](../../../../images/feko/example_guide/EG_H05_characterised_surfaces/tr_theta.png)
Figure 2. Transmission / reflection coefficient versus plane wave phi.
![](../../../../images/feko/example_guide/EG_H05_characterised_surfaces/tr_phi.png)
Tip: For (nearly) constant coefficients (such as in ϕ), use one θ cut to describe the
surface.
Note that the FSS elements have relatively good transmission through all θ and ϕ (> 0.7) at 10 GHz.
The plots also show that sufficient resolution (6°) was used to capture the variations in θ and ϕ.
