Creating the Model
Create the model in CADFEKO. Define any ports and sources required for the model. Specify the operating frequency or frequency range for the model.
- The waveguide port is placed on the YZ plane and the horn is centered with respect to these axes.
- The phase centre of the horn is located inside the flare. The far
field is calculated with the offset axis origin at X = -21.6 cm.
- The phase centre is required for accurate placement of the equivalent sources, but this calculation is beyond the scope of this example.
- The phase centre varies over frequency. However, for the narrow bandwidth of this example, this variation is ignored.
