Compare Material Data
Compare materials using the properties data provided by the provider.
Select the check box
of the required materials to compare.
The Compare button is enabled.Figure 1. Select Materials to Compare
Click Compare.
The selected materials data is displayed in a table format. The compared material data between general information and properties data is displayed for the selected materials.
Figure 2. Compare Material Data
Select Show difference only.
Only the difference in data among the selected materials is displayed.
Figure 3. Show Differences Only
- Optional:
You can add your comparion list of materials to favorites.
Figure 4. Add to Favorites
The comparision list is appended to your unsaved favorites. Use the Favorites menu to view and for more options.
