Clear the Access Limit for a User
You can remove the set access limit for a user.
You can remove, the license access limit at suite level for a user.
  1. Click License Settings > Managed > Feature Restrictions.
  2. Click the Clear Limit button.
    The Clear User Access Limit dialog box is displayed.
    Figure 1. Clear User Access Limit
  3. Select the user's email address from the drop down list.
  4. Select the License ID under which the access limit was set for the user.
  5. Click Submit.
    The license limit is removed for the user.
