Smart Home Tutorial Using ESP32 Kit
In this guide, you will go through the process of setting up a Smart Home system using an IoT kit that includes an ESP32 microcontroller, sensors, and actuators. By the end, you will have a working example of a connected smart home system that can be monitored remotely, a dashboard to keep track of the metrics and visualize real-time data, and some logic implemented.
Requirements
Before starting, ensure you have met the following requirements and make sure you have the following components ready:
  • Kit reference: KEYESTUDIO ESP32 Smart Home IoT Stem Kit Compatible with Arduino IDE, ESP32, Python C
  • Altair IoT Studio account
  • Arduino IDE installed
Note: This tutorial is based on code from https://www.keyestudio.com/. Some portions have been adapted to fit the specific needs of this implementation but the original files are provided during the tutorial in case you want to use them.
Steps in This Tutorial
