| Toggle Functionality |
The LED turns on when the button is pressed and turns off
when the button is pressed again, effectively toggling its state
with each press. |
Publish the LED status to the IoT platform via MQTT whenever
it changes. This updates the value of the property. |
| PIR Motion Sensor |
Detects movement within its range. |
Publish the PIR status to the IoT platform via MQTT whenever
| Humidity and Temperature Sensor |
Reads humidity and temperature values and displays them on an
LCD screen. |
Publish sensor readings to the IoT platform via MQTT when
significant changes occur. |
| RGB LED |
Users can choose the LED mode by updating the value of a
property in IoT Studio. |
- Use MQTT to receive mode changes from the IoT platform
and update the LED accordingly.
- Ensure the current mode is published back to the
platform for synchronization.
| Fan |
The fan is controlled by a second physical button and can
also be controlled remotely from IoT Studio through
actions. |
When the fan’s status is changed (either manually or via IoT
Studio), a message is sent via MQTT to update the platform with
the new state, and the corresponding action is performed (turn
it on or off). |
| Window |
The window's status (open or closed) can be controlled
remotely via IoT Studio. |
When the window's status is changed, a message is sent via
MQTT to update the platform with the new state, and the
corresponding action is performed (turn it on or off). |
| Raindrop Sensor |
The raindrop sensor monitors rainfall intensity. If rain is
detected, the sensor value changes and is updated on the
platform. |
The raindrop sensor constantly monitors for rain, and any
change in its value is also sent to the platform via
MQTT. |
| Door |
The door's status (open or closed) can be controlled remotely
via IoT Studio or triggered by scanning the correct RFID
card. |
When the door status changes (either from an RFID scan or a
command from IoT Studio), the new status is sent to the platform
via MQTT. |
| RFID Sensor |
- The RFID sensor authorizes or denies access based on
predefined access cards.
- When an authorized RFID tag is scanned, the door opens
for 3 seconds, and a success message is displayed on the
LCD.
- If an unauthorized RFID tag is scanned, a "denied"
message is shown on the LCD.
Successful or denied access attempts trigger corresponding
events. If access is denied, a SecurityAlert
event is sent to the platform, and users can be
notified through email or push notifications. |
| Gas Alarm |
When gas is detected, a "warning" message is displayed on the
LCD to alert the occupants. |
