Connect Altair IoT Studio with Altair AI Hub
This tutorial will guide you through the process of learning how to access the data stored in IoT Studio to develop models and Machine Learning (ML) processes in Altair® AI Hub™, and how to deploy the ML or Artificial Intelligence (AI) workflows to be accessible from IoT Studio to execute them in real-time.
In this tutorial, you will:
- Access the data stored in IoT Studio from AI Hub to create models and ML processes
- Build a REST API deployment to make the model created in AI Hub accessible to clients over the internet
- Build a function in IoT Studio and define the logic to execute the model accessible through a REST API
Note: In this tutorial, a simple workflow to get the data will
be defined. To learn more about developing models and ML processes, access AI
Hub documentation here.
Click below to watch the tutorial.
Additional information
Listed below you will find additional
documentation about the features covered in the tutorial:
- IoT Studio - AnythingDB
- IoT Studio - Access Control: Apps
- AI Hub - Projects
- Connections
Additional information about the IoT connector is available here.
- Content
- REST API Deployments
- Connections
- IoT Studio - Functions
An example of the Python code for the function to access the AI Hub deployment through REST API is provided:
import requests
def handle(req):
url = '<enter-your-deployment-url>'
headers = {
'Authorization': 'enter-your-security-token',
'Content-Type': 'application/json'
# The variable data will store the inputs required to execute your model correctly
data = {
response = requests.post(url, headers=headers, json=data)
print(response.text)
return {
"status_code": 200,
"body": req.body.decode('utf-8')
Note: You could improve the logic defined in the Function, for
example, to get the data in real-time from any asset connected to the IoT
platform and store the prediction result from executing the AI Hub deployment in
IoT Studio, while triggering an action based on the result.
