Build a Function for the Edge
- Go to the section and create a new Function by clicking on the +New Function button.
- Select Edge as the Function type and select the architectures you want to build the function for.
When done with the code and libraries, click Save.
When finished, the status of the Function displays as “Built”. It can now be deployed to the Edge.
