Function Log
The Function Log allows you to retrieve the logs from your Functions.
Choose one of the existing Functions, and if desired, enter a date range to
filter. The logs from the specified time frame are displayed.
Figure 1. Note: Use the Search bar and Filter field to adjust the logs that display.Figure 2.
- To display the logs for multiple Functions, minimize the current view and repeat the process.
