Telemetry Data
If only one property to report is specified then the telemetry will return just the value of that property. For example:
{ "data": { "analog-input,0,present-value": "1197.831787" }, "messageType": "propertyStatus", "thingID": "01F6PEY4T318ZCQ6A0H638GWF6", "timestamp": 1622451000004261 }
If multiple properties to report are specified then the telemetry will consist of an object with the properties as the keys and the return values as the object values. For example:
{ "data": { "analog-input,0,present-value,units": { "present-value": "1197.831787", "units": "cubic-feet-per-minute" } }, "messageType": "propertyStatus", "thingID": "01F6PEY4T318ZCQ6A0H638GWF6", "timestamp": 1622451000004261 }
