Close Job Submission Form
Enable the job submission form to close after you submit your job.
The job submission form appears while trying to submit the job. By default the job submission form does not close after you click Submit Job in the job submission form.
Click
Select Preferences.
Access Web Preferences is displayed.
Click Job Submission in the left panel.
The Job Submission panel is displayed.Note: By default, all the options of job submission notification is disabled.
Figure 1. Job Submission Form Option
Check Close Submission Form after Submission? to enable
the job submission form to close after you click Submit
Job.
Note: You can also set the job submission notifications.Note: Click
to go back to the previous
page.
