Flow Description Language (FDL)
- Write a description of the flow using the Flow Description Language
- Pass the description to
vovbuildto import the flow into FlowTracer - Execute the flow using parallel retracing
This chapter introduces FDL, the Flow Description Language, which is an extension to Tcl. Common uses of the language are demonstrated. For an introduction to Tcl, you can check out the Tcl quick guide.
For information about using Makefile to FDL utility, refer to Makefile to FDL Utility.
With FDL, you can concentrate on the flow description. Compared to traditional methods using scripts or makefiles, you do not have to worry about setting up the environment, representing dependencies, deciding the job scheduling, checking the proper completion of each job, capturing stdout and stderr, because FlowTracer takes care of all of that. Instead, you can concentrate on the "recipe" for the flow.
FDL consists of single letter procedures such as J, T, E, R, I, O, N and a few others.
Examples of Flows
J vw cp aa bbThe J means that we want a job with command line vw cp aa
bb. The environment for the job will be BASE by default, and the
working directory is the current directory.
E, which must be invoked before the
J.
E "BASE+D(MYVAR=aaa)"
J vw cp aa bbR, which must also be called before the
J:R "linux"
J vw cp aa bb
In alternative to J, you can use the procedure T to
add a job to the flow. In this case, however, it is also important to add explicit
dependencies to the flow, using I and O. Both
I and O must be called after
T. For a detailed description of the difference between
J and T, check the appropriate section.
T vw cp aa bb
I aa
O bb
for, while, foreach to build
arbitrarily complex flows. Here is an example of a for loop:
E "SYNTHESIS"
for { set i 0 } { $i < $numberOfBlocks } { incr i } {
J vw runSynthesis $block($i)
} Simple conditionals can be handled with if and
switch:
foreach block $listOfBlocks {
set type $blockType($block)
switch $type {
"memory" {
J vw genMemory $block
"gates" {
default {
VovFatalError "Unknown block type '$type' for '$block'"
Also fundamental in Tcl is the ability to create procedures that can be used to make your flow definition more modular:
proc compile { cfile } {
global CASE
set cc $CASE(cc)
set flags $CASE(flags)
J "vw $cc -c $flags $cfile"
set CASE(cc) gcc
set CASE(flags) "-I../include -g"
compile aa.c
compile bb.c
compile cc.c
