Conditional Flows
There are many different types of conditions that affect the shape of the flow, from conditions that are known at "build-time", meaning at the time vovbuild is first executed, to conditions that are known only after one or more jobs have been executed. In this section, we examine a couple of common types.
Build-time Conditions
Conditions that can be evaluated at build time are the easiest to handle because we
can use standard Tcl procedures like
if and
switch.
if { $blockType == "large" } {
J vw runFastRouter $block
} else {
J vw runNormalRouter $block
}Complex Conditions
Sometimes a flow depends on a computation that involves one or more complex tools. For example, we may have a methodology that says:
If the block meets timing, then publish the block, else improve timing
where the condition "meets timing" is computed by running expensive (in term of
software licenses) and time-consuming tools. The way to handle such flows is to
build them one piece at a time and to include the invocation of the
vovbuild itself as part of the flow.
# This is BlockFlow.tcl
# A procedure to get the slack (timing) of a block.
# A negative slack means that the block does not meet timing.
proc getBlockSlack { file step } {
set fp [open $file]
set slack [read $fp]
close $fp
return $slack
# In the first part of the flow, we run a few jobs
# and then we run another vovbuild.
proc partOne { block } {
S "Block:$block:Step1" {
E WORK
J vw runSynth $block
J vw measureSlack $block -step 1
O reports/step1/$block.timing
J vovbuild -T -f BlockFlow.tcl -- -step 2
I reports/step1/$block.timing
# In the second part of the flow, we get the
# timing of the block and then decide what to do
# based in it.
proc partTwo { block step } {
set n1 [expr $step -1 ]
set slack [getBlockTiming "step$n1/$block.timing"]
S "Block:$block:Step$step" {
if { $slack >= 0 } {
# The block meets timing.
J clevercopy -m 644 $block.v ../../netlists
} else {
# The block does not meet timing.
E WORK
R "timing_opt_license"
J vw refineTiming $block -step $step
O reports/step$step/$block.timing
J vovbuild -T -f BlockFlow.tcl -- -step [expr $step + 1]
I reports/step$step/$block.timing
# Main controller code for the flow.
set block [file tail [pwd]]
set step 1
while { $argv != {} } {
set arg [shift]
switch -glob -- $arg {
"-step" { set step [shift] }
switch $step {
1 { partOne $block }
2 - 3 - 4 - 5 - 6 { partTwo $block $step }
default {
VovFatalError "Too many iterations: timing does not converge"
