Execute Jobs From the Command Line
Execute Tools
You can build a design flow by executing tools, provided you activate runtime tracing for each tool in the flow. This is done by executing each tool from within a VOV Wrapper. The examples in this page use the most sophisticated wrapper, called vw2.
At runtime, each tool connects with the server and exchanges information about its execution environment and its I/Os (input/output).
% ves BASEaa to bb without FlowTracer, you will probably use the tool cp and
the command:% cp aa bb% vw2 cp aa bb% vw2 diff aa bb
% vw2 gcc -c -I../include hello.c
% ves SYNOPSYS
% vw2 dc_shell -f alu.scr% ls
% vi hello.c
% mail boss@work.org < todo.txt% vw2 cp aa bb
% vsx !
00234069 VALID ${PROJECT_DIR}/txt/aa
>>>> Node 00234051 VALID vw2 cp aa bb
00234076 VALID ${PROJECT_DIR}/txt/bb
Pipes and Redirection
To redirect stdout to a file, use the redirection option `>'. From the command line, you must quote or escape `>' so that vw2, not the shell, will do the actual redirection.
% vw2 cat aa bb \> cc
% vw2 cat aa bb ">" ccUnlike the shell, vw2 requires that the redirection options is separated by spaces from the other command line arguments.
% vw2 cat aa bb \| grep ciao \> ccOnly stdout can be piped and/or redirected at this time.
Tools That Need No Wrapper
% clevercopy aa bb
% vov clevercopy aa bb
Troubleshooting and Verbosity
In versions earlier than 2016.09u9, setting VOV_VW_VERBOSE to
a nonzero value would cause the vw/vov wrapper to
create a file called .vw2_pid_%d_verbose.out that received
verbose messages from the wrapper. Using the -v option would add
some messages, but not as many as using VOV_VW_VERBOSE
because many of the messages would get piped to /dev/null. In addition, VOV_VW_LOGNAME
could be used to modify the name of the file for the verbose output.
In 2016.09u9 and later, setting VOV_VW_VERBOSE
still creates the file and VOV_VW_LOGNAME can
still be used to change the name, but now, using -v also does the
same thing. Setting VOV_VW_VERBOSE=3
in the environment is equivalent to using -v -v -v as options to
vw/vov. In addition, if VOV_VW_VERBOSE is
3 or greater, or 3 or more -v arguments are passed, an additional
file called .vw2_pid_%d_verbose_env.out gets written with the
full contents of the environment and equivalences used for the job. The VOV_VW_ENV_LOGNAME
environment variable can be used to change the name of this file.
Since a job can potentially run on different operating systems, the equivalences may vary depending on which machine the job was run on. The environment, however, should be the same on different machines.
