Environment Management: Commands
The commands described in this section are used to manage named environmentsand can also be used independently of VOV.
| Command | Description |
| vel | List all available environments. |
| ves | Switch between environments. |
| vec | Create an environment variable for each LOGICAL name used in the equiv.tcl file (works only if connected to a VOV project) |
vel: List Environments
% vel
vel: message: Environment directories:
1 /release/VOV/latest/sun5/local/environments
1 * tcl BASE UNIX utilities, X11, and VOV.
1 . tcl D Define variables: Usage: ves "+D(V1=value1,...)"
1 . tcl DEFAULT Just a name for whatever you already have.
1 . tcl DOT Append "." to the path variable
1 . tcl GNU gcc, g++, emacs1 . tcl OCTTOOLS Octtools 5.1
1 . csh CSHRC Source the ~/.cshrc file.
1 . csh LIBTECH Library Technologies, Inc.
1 . csh SOS SOS from ClioSoft (Revision control manager)
1 . csh SPICE The analog simulator SPICE.
1 . csh TRAINING Used for VOV Basic Training
1 . tcl MSDEV Windows: VisualC++ development.vel shows a list of directories where environments can be
found. Then for each environment, the command shows: - The ordinal number of the directory where the environment definition resides
- An asterisc to identify the current environment (BASE in the example) or a dot for all other environments
- A label to identify the syntax used to describe the environment, which is either Tcl or csh
- The name of the environment
- A short description of the environment
ves: Switch Environment
% ves BASE
% ves SPICE
% ves +TRAINING
% ves BASE+TRAINING
% ves 'BASE+D(DISPLAY=tahoe:0.0)'
% ves BASE+D,DISPLAY=tahoe:0.0- Exiting the current environment
- Entering the new environment
The third and fourth examples illustrate the use of combined environments. If you prefix the environment name with a "+", VOV enters the new environment without exiting from the current one.
The fifth example shows the use of Parameterized Environments. Proper quotation must be used because parameter passing requires special characters, the parentheses, which can be consumed by the shell if not protected.
The sixth example show the same parameterized environment specified using the "comma syntax" instead of the parentheses. This syntax is easier to use because it does not require quoting of the environment specification.
A side effect of switching environment is that the prompt is changed, unless the variable VOV_USE_VEP is set to 0.
- Using a Tcl file as Environment
- You can also use
veswith a Tcl file as argument. A typical example can be the setup.tcl file in the SWD directory of a project% ves proj.swd/setup.tcl
vec: Promote Equivalences to Environment Variables (UNIX only)
The equivalence file may establish an equivalence between a logical name and a physical path and it is not necessary that the logical name be the value of a predefined environment variable.
vtk_equivalence WORK1 /remote/projects/work1 so that
the files under /remote/projects/work1/* will be referred to
with the name ${WORK1}/*. When working from the command line, it may be convenient to define the variable WORK1. This can be done automatically with the command vec.
% echo $WORK1
WORK1: Undefined variable.
% vec
% echo $WORK1
