Makefile Conversion
If you have Makefiles, you can use vovmake to extract flow information from the Makefile. This approach is intrinsically less capable and less reliable than using FlowTracer's Flow Description Language (FDL) to describe your flows, because of the limitations of the Makefiles. For example, the Makefiles do not have information about the resources (e.g. licenses, RAM) required for each job in the flow, in which case you may want to augment the description contained in the Makefile with a vovmake.config.tcl file.
- make is commonly used recursively, so there is no one instance of make that contains the complete dependency graph
- make does not have any graphical user interface, so you need to read log and dump files carefully when troubleshooting.
- the language of makefiles is complicated and arcane, and uses many tersely-named special variables. This is OK for experts, but is a barrier to new or casual users.
With some exceptions, running your Makefiles with vovmake can
provide a valuable visualization of the structure of the Makefiles.
You can use your Makefiles as a starting point, then run your computation with FlowTracer, or continue to maintain the makefiles, and just use FlowTracer to visualize what they are doing.
Often the flow can be brought up-to-date more quickly by FlowTracer than by make, by running multiple jobs in parallel over the network. Since FlowTracer is client-server, all users see the same state of the computation in their GUI or browser.
Prerequisites for Running vovmake
You must first start a FlowTracer
project, managed by the vovserver program. This can run on
the same or a different host from where you run vovmake.
% vovproject create <project_name>
% vovproject enable <project_name>% make all% vovmake all% vovmake -help
% vovmake -clean
DESCRIPTION:
This is a script used to convert makefiles into FlowTracer flows.
1. First the makefiles are interpreted by a modified gmake,
called gmake_with_vov_extension, which contains some
Altair Engineering extension and supports the option -F to dump
the dependencies into Tcl file.
2. The resulting Tcl file is then mapped into a flow by means of the
script $(VOVDIR)/tcl/vtcl/vovmaketoflow.tcl.
USAGE:
% vovmake [VOVMAKEOPTIONS] [gmake_options]
VOVMAKEOPTIONS:
-help -- Print this help.
-clean -- Just cleanup the generated files.
-nocleanup -- Do not cleanup temporary files
(for debugging).
-gmake <GMAKEBIN> -- Use specified gmake binary
This must be one with the Altair Engineering
extensions.
Default gmake_with_vov_extension
-build "options" -- Options passed to vovbuild, with flow
-version -- Show gmake version and exit
-wrapper <dfltwrapper> -- Specify default wrapper for jobs in
flow. It is passed to vovbuild.
-run [ft|no] -- Run Flowtracer to get more information about
input makefile. Default is ft.
EXAMPLES:
% vovmake -help
% vovmake install
% vovmake <SOME_MAKE_TARGET>
% vovmake -clean
% vovmake -nocleanup all
% vovmake -gmake ~/bin/my_gmake_with_vov_extension
% vovmake -wrapper vrt
% vovmake -build "-env BASE" install
To find the options of vovmaketoflow.tcl, you can use
% vovbuild -f $VOVDIR/tcl/vtcl/vovmaketoflow.tcl -- -help
How vovmake Works
vovmake operates as follows:- It calls
gmake_with_vov_extensionto parse the Makefiles and generates an intermediate flow file called /tmp/vovmakeUSERNAME/TIMESTAMP/vovmakePID.tcl. - This intermediate flow file is then processed by the Tcl script
vovmaketoflow.tcl which transfers the dependencies
derived from the Makefiles into the FlowTracer
server.The processing of the Makefile rules occurs as follows:
- Simple rules (one-line commands) are preserved and appear as a job in the flow
- Complex rules, i.e. rules that have either multiple lines, or multiple commands, or redirections, are encapsulated into a local shell script in the directory vmake_scripts
- The dependencies in your flow graph will be those in your makefile
vovmakeissues the commandvsrto request that the flow graph should be brought up-to-date
Limitations on makefiles
There are many different versions of make available, that support
different commands. GNU make is the most common, and it has some functionality that
is not supported by vovmake.
Makefiles that simply define variables, targets, and recipes to make the targets should work OK.
Suggestions
Use vovmake only to "build" stuff, not to run targets that clean up.
Many makefiles have a target named 'clean' or the like which will remove
intermediate and output files, leaving only the sources. It is common to compensate
for incorrect or incomplete dependencies by using the 'make clean; make all'
sequence.
When dealing with recursive make, we recommend you start from the leaves, i.e. the deepest directories. Try to do one directory at a time.
Some Results Using Compilation Examples
The following table describes the results obtained at Altair by using
vovmake on some common open-source packages.
| Package Name | Comments | Size of resulting Flow |
| GNU make 3.80 | One shot build with the
usual:
less than 400 nodes |
| mysql 5.0.19 | Complete build succeeds. You can observe multiple
passes:
1000 jobs and 4400 files |
| GNU gdb 6.3 | On Linux, you get a flow graph with about 2300 nodes. Exclude the
"maybe-*" targets by adding vtk_exclude_rule -regexp
{/maybe-} to exclude.tcl file.
About 2300 nodes |
| valgrind 2.4.0 | The package almost builds valgrind in one shot, but shows a very
"interesting" makefile system with a few conflicts between addrcheck
and memcheck and some failures because of missing '*.Tpo'
dependencies.
About 120 |
