| A |
Add annotations to the most recently declared node. |
| AD |
Declare an artificial dependency between two jobs. |
| D |
Set the database for subsequent files. |
| E |
Set the environment for subsequent jobs. |
| FLAGS |
Specify additional flags for the most recent job. |
| I |
Declare an input dependency. |
| J |
Declare a job and use the capsule to compute IO's (see also T
and P). |
| L |
Set the legal exit values for subsequent jobs. |
| N |
Set the jobname. |
| O |
Declare an output dependency. All jobs require at least one
output to be valid. |
| P |
Add a property to the most recently mentioned object. |
| PARALLEL |
Declare the parallelism between two or more tasks and
subflows (See also TASK and SERIAL). |
| PJ |
Declare a job to be executed periodically (see also T and
J). |
| PRIORITY |
Set the priority to be used for the subsequent jobs. |
| R |
Set resources for subsequent jobs. |
| RUNMODE |
Set 'runmode' for subsequent jobs. |
| S |
Precise definition of a set of jobs. |
| S+ |
Append jobs to a set. |
| SERIAL |
Serially order a number of tasks and subflows (See also TASK
and PARALLEL). |
| START |
Start running jobs -- rarely used. |
| T |
Declare a job (see also PJ and J). |
| TASK |
Declare a job with no specific dependencies (see also SERIAL
and PARALLEL). |
| X |
Set the expected duration for subsequent jobs. |
| Z |
Set the zippable flag for a list of files. |
