Forcing Dependencies
To force a dependency that is not a "runtime dependency" you can include "Sticky" dependencies to your flow description. Since all jobs require at least one output to be valid, using sticky is a good way to keep a dependency around without having to instrument it or declare it as an output during execution of the job.
Example:
J vw cp aa bb
I -sticky /usr/man/man1/cp.1 To force all dependencies to be sticky by default, use the option -s
in vovbuild when building the
flow:
% vovbuild -s -f Flow.tcl
