J versus T
In FDL there are two procedures that can be used to add a job to a flow: T and J. Which one should you use?
The difference between J and T is that J evaluates the capsule for the tool while T does not. If the tool you are adding to the flow has no capsule, there is no difference between J and T. On the other hand, if a capsule is available, J will give you a more compact flow description. Even with a capsule, you may want to consider using T, with some explicit I's and O's in order to build the flow more quickly.
| Procedure | Advantages | Disadvantages |
| J (with capsule evaluation) | More compact flow description. Same as T if there is no capsule. |
Requires a capsule to be effective. Capsule evaluation may be slow. |
| T (no evaluation of capsule) | Faster evaluation. | Must declare explicit I's and O's dependencies to avoid false job executions. |
# This uses the capsule vov_cp.tcl
J vw cp aa bb
# This instead does not use the capsule.
T vw cp aa bb
I aa
O bb
