Dependencies in FDL
In most of the flow examples, we have not shown any explicit dependency, mostly because we have used J rather than T.
T vw cp $in $out
I $in
O $out
- The dependencies you describe in the Flow Description only form the starting point of the flow graph.
- In FlowTracer the dependencies for each job are dynamically computed by the tool integration at run time.
- In FlowTracer all jobs must have at least one output dependency in order to be considered valid.
- In Accelerator, there is no runtime tracing, and the flow graph is not updated at run time.
Incorrect Dependencies
- Incorrect Input
Dependency
# Incorrect input dependency T vw cp aa bb I cc; ##### incorrect input I aa O bbThis example will generate an spurious input in the flow. If the file cc changes, it will invalidate the job and will cause it to be re-run needlessly. However, running the job will fix the input dependencies for
bbby dropping the dependency oncc. - Incorrect Output
Dependency
# Incorrect output dependency T vw cp aa bb I aa O bb O cc; ##### Spurious outputThis example will generate a spurious output in the flow. However, running the job will fix the output dependencies by dropping the output dependency on
cc.
Arbitrary Dependencies with DEPENDENCY or with AD
DEPENDENCY $J1 $J2or
AD $J1 $J2
These procedures create a PHANTOM place and declare it as a sticky output to the job with VovId J1 and as a sticky input to the job with VovId J2.
set j1 [J vw cp aa bb]
set j2 [J vw cp aa cc]
# Force the second job to be executed after the first job, even
# if there is no particular reason for it. You can also use the
# short name 'AD' (for Artificial Dependency).
DEPENDENCY $j1 $j2 SERIAL {
TASK cp aa bb
TASK cp aa cc
}which also creates an artificial dependency between the two tasks by means of a "sticky phantom". This is one way to force a job to have an output without explicitly declaring it at runtime.
