Stair Trunks
The tasks that can be carried out in the Decks options are:
  • Add Item
  • Delete Item
  • Enable changes
  • Save changes
  • Undo changes
  • Duplicate Item
  • Customize grid columns
  • Save as XLSX Report
  • Show/Reset Column filter
  • Update EDC
  • Upload File
  • Define Stair Trunk, WBS II level,MVZ,Frame min,Frame Max,Ymin,Ymax,Zmin,Zmax
Note:
  • UOM is not editable
  • Frame Max, Ymax, Zmax value should be greater than Frame min, Ymin, Zmin
