Select Multiple Items
The Multiple Item Selection functionality facilitates the selection of multiple parts so that you can modify the attributes (maturity, for example) of the selected parts with common attribute values. When you edit multiple parts at the same time, all the selected parts are updated with the same values.
To select multiple items:
This functionality is available in the BoM Management section of Weight Analytics.
Note: You cannot have the unit weight defined with empty maturity or vice versa. When you modify the maturity of parts with different weights, the weights of all the parts are modified.
  1. Click the Enable multiple selection icon.
    Each row in the part list displays check boxes that enable your selection.
  2. Select the checkboxes for the parts that require modifications.
    The Open popup for multiple part changes. icon is enabled.
  3. Click the icon.
    The Multiple part modification window is displayed.
  4. Modify the attributes of the selected parts in this window and click Apply changes.
