Grid Attributes
In multiple areas of WA, the parts of the products that exist in the database are displayed in the Grid View.
| Attribute Name | Definition / Meaning | Remarks |
| Code | Indicates the code name assigned to the part or assembly. | |
| Revision | Indicates the Code and Revision together that form a unique identity of a part. The part code is not changed once defined, but the revision number is changed by weight engineers upon changes done to the parts. | |
| Description | Indicates the text that describes the part. | For example: Frame at location 12432. |
| Level | Indicates the level of the part in the assembly hierarchy. | A 0 means the highest/root/product level. A level 1
part is the first sub-level below the top level product, a level 2 part is
the second sub-level below the top level product and so on. |
| Weight Maturity | Indicates the weight maturity of the part in the current snapshot. | The options are:
| Checked | Indicates that the part has been manually verified by a Weight Engineer and marked accordingly. | |
| Mass - Weight UoM | Indicates the unit of measurement used for Weight in the selected Program. | |
| Mass - Unit Weight | Indicates the weight of a single unit of a part. | |
| Quantity - UoM | Indicates the unit of measurement used to measure quantity of the part. | |
| Quantity | Indicates the number of units of the part available in the product. | |
| Mass - Total Weight | Indicates a calculated value. In case of assemblies the total weight is a roll-up of the weight of the sub parts and assemblies. | Total Weight = Unit Weight x Quantity. |
| CoG UoM | Indicates the unit of measurement used to measure the Center of Gravity. | |
| Center of Gravity - X CoG | Indicates the X coordinate of the Center of Gravity of the part. | |
| Center of Gravity - Y CoG | Indicates the Y coordinate of the Center of Gravity of the part. | |
| Center of Gravity - Z CoG | Indicates the Z coordinate of the Center of Gravity of the part. | |
| Inertia UoM | Indicates the unit of measurement used to measure the Moment of Inertia of the part. | |
| Inertia - Ixxcg | Indicates the Moment of Inertia of the part about its principle X axis. | |
| Inertia - Iyycg | Indicates the moment of Inertia of the part about its principle Y axis. | |
| Inertia - Izzcg | Indicates the moment of Inertia of the part about its principle Z axis. | |
| Inertia - Ixycg | Indicates the products of I along the X-Y plane. | |
| Inertia - Ixzcg | Indicates the products of Inertia along the X-Z plane. | |
| Inertia - Iyzcg | Indicates the products of Inertia along the Y-Z plane. | |
| Part Details - Class | Indicates text fields where additional information about the part can be specified as required. | |
| Part Details - Material | ||
| Part Details - Process / Finish | ||
| Part Details - Supplier | ||
| Part Details - Design | ||
| Part Details - System | ||
| Part Details - Type | ||
| Part Details - Classified | Indicates if the part is a classified part. | Classified parts can be hidden from certain users based on the permissions assigned to the user role. |
| Change Details - Change Reason | Indicates a pre-defined reason for changing the attributes or assembly structure of the part. | The pre-defined options are:
| Change Details - Change Detail | Indicates a text field for providing additional text related to the change. | |
| Notes | Indicates a text field to add notes about the part. | |
| Functional Views - US Code | Indicates the functional US Code for the part. | |
| Functional Views - Automotive | Indicates the functional ATA100 code for the part. |
