Two new machine types are available
- The polyphase synchronous machine with permanent magnets (Inner and Outer Rotor)
- The wound field synchronous machine with inner salient pole (Inner Rotor)
List of available machines from the Altair® FluxMotor® supervisor (1) and in Motor Catalog (2) |
From the supervisor, the user can click on a type of motor (1) and get into Motor Factory for designing motors.
8 types are currently available, including 3 new ones (in bold font below):
- SM_PM_IR_3Ph: 3-Phase synchronous machines with permanent magnets – Inner rotor
- SM_PM_OR_3Ph: 3-Phase synchronous machines with permanent magnets – outer rotor
- SM_PM_IR_nPh: 3-Phase synchronous machines with permanent magnets – Inner rotor
- SM_PM_OR_nPh: 3-Phase synchronous machines with permanent magnets – outer rotor
- SM_RSM_IR_3Ph: 3-Phase Reluctance Synchronous Machines – Inner rotor
- SM_WF_ISP_IR_3Ph: 3-Phase Wound Field Inner Salient Pole Synchronous Machines – Inner rotor
- IM_SQ_IR_3Ph: 3-Phase induction machines with squirrel cage – Inner rotor
- IM_SQ_OR_3Ph: 3-Phase induction machines with squirrel cage – outer rotor
