Settings
Introduction
Two buttons give access to the following setting definitions: Thermal and Mechanics. Each kind of setting is briefly defined here.
Additional information can be read in the document: MotorFactory_SMWF_ISP_IR_3PH_Test_Introduction – sections dealing with settings.
Thermal settings
In the thermal settings:
  • You can define the temperatures of active components (windings and dampers (bars + end ring)) to define the physical properties of the materials needed to directly run the tests.
Temperatures of the machine active components to be considered for characterizing the physical properties of the associated materials.
For more details, please refer to the document: MotorFactory_SMWF_ISP_IR_3PH_Test_Introduction – section “thermal settings”.
Mechanical loss model parameters
A dialog box allows for defining the mechanical loss computation model.
For more details, please refer to the document: MotorFactory_SMWF_ISP_IR_3PH_Test_Introduction – section “Mechanical loss model settings”.
