Settings
Thermal settings
One button gives access to the thermal settings:
- External fluid temperature
- Cooling circuit fluid temperature
Note: The external fluid temperature corresponds to the
temperature of the fluid surrounding the machine. It is also considered the
temperature at the “infinite” for the computation of radiation from the frame to
the infinite.
Note: The cooling circuit fluid
temperature exists only when a cooling circuit has been added by the user in the
design environment. In this case, this input describes its fluid inlet
temperature.
Target temperatures
Please, refer to the section "Targets"
X-Factors
Please, refer to the section "X-Factors"
