Introduction
The main inputs of this test correspond to a set of losses to be considered for evaluating the thermal behavior of the machine in a transient mode.
Standard inputs
Speed
The speed of the machine is to be considered.
Set of losses
The losses to be defined are the following:
        - Stator Joule losses
 - Stator iron losses
 - Magnet losses
 - Rotor iron losses
 - Mechanical losses
Maximum allowed deviation
The maximum temperature deviation allowed to consider the optimization algorithm has converged. All the final temperatures must have a lower deviation.
Input import
Please, refer to the section "Input import".
Advanced inputs
There are no advanced inputs required for this test.
