Standard inputs
Field current
The current supplied to the field winding of the machine: “Field current” must be provided.
Speed
The operated speed of the machine to be used in the back-EMF test.
Advanced inputs
The list of advanced inputs dedicated to this export are listed below.
Number of computations per electrical period
The default value is equal to 50. The minimum allowed value is 13.
Number of computed electrical periods
The default value is equal to 2. The minimum allowed value is 1 and the maximum value is equal to 10.
Rotor initial position
By default, the “Rotor initial position” is set to “Auto”.
Mesh order
The default level is second order mesh.
Airgap mesh coefficient
