Export the Installation Configuration
Export cluster, profile and application definition information to a zip file.
- Open the Windows system tray.
Double-click the Access Desktop icon
Click
- Select Export Config from the menu.
Select a folder where the exported configuration will be saved.
A zip file called AltairAccessConfig.zip is created in the selected folder.
