System Requirements
Supported platforms and hardware requirements for using Access Desktop.
Supported Platforms
Access Desktop is supported on the following:
- Windows 10 64-bit platform
- Linux
Hardware Requirements
Access Desktop requires a minimum hardware configuration:
| Hardware | Minimum Requirement | Recommended |
| CPU | 2 CPU cores with a minimum speed of 2.5 GHz | 4 CPU cores with a minimum speed of 2.5 GHz |
| Memory (Physical) | 2 GB | 8 GB |
| Disk Space | 2 GB | 4 GB |
