2024.2.1
Set the user Access Desktop preferences.
Latest features available with Altair Access™ Desktop.
Altair Access Desktop provides a simple, powerful and consistent interface for submitting and monitoring jobs.
Video tutorials to help you get started with Access Desktop.
Supported platforms and hardware requirements for using Access Desktop.
Supported product configurations for using Access Desktop.
Log into Access Desktop and register an HPC cluster so that you can begin submitting jobs to the Workload Manager.
Upgrade to the latest version of Access Desktop after receiving a notification that an upgrade is available.
Schedule jobs to run on an HPC cluster by submitting them to the Workload Manager.
Monitor the status of your jobs, monitor memory and core utilization, view a list of job files, or view a list of job details.
Terminate and remove unwanted jobs.
Add, update, or delete HPC clusters.
Create and remove job profiles.
Disable the copy back output files option.
Map a network drive to create a shortcut to the shared file system path.
Configure a shared file system path to submit jobs from the mapped server.
Export cluster, profile and application definition information to a zip file.
Log files can be used for monitoring and troubleshooting the application.
Removes the invalid clusters from the system completely.
Map or add a name to the Webdav drive in your local machine so that the files in the job's running directory on the HPC complex can be accessed and viewed.
Application definitions are a predefined set of instructions to describe application parameters, store responses and prepare responses for job execution.
Click > Preferences.
