2024.2.1
Add, update, or delete HPC clusters.
Latest features available with Altair Access™ Desktop.
Altair Access Desktop provides a simple, powerful and consistent interface for submitting and monitoring jobs.
Video tutorials to help you get started with Access Desktop.
Supported platforms and hardware requirements for using Access Desktop.
Supported product configurations for using Access Desktop.
Log into Access Desktop and register an HPC cluster so that you can begin submitting jobs to the Workload Manager.
Upgrade to the latest version of Access Desktop after receiving a notification that an upgrade is available.
Schedule jobs to run on an HPC cluster by submitting them to the Workload Manager.
Monitor the status of your jobs, monitor memory and core utilization, view a list of job files, or view a list of job details.
Terminate and remove unwanted jobs.
Add and establish a connection to the HPC or Workgroup using SSH by registering it so that you may begin submitting and monitoring jobs.
Add and connect to Access Web server using HTTPS to submit and monitor jobs.
Add and connect to Altair One server to submit and monitor jobs.
Update the staging location and the central repository server address details.
Remove a cluster when you no longer want to submit and manage jobs on that cluster.
Create and remove job profiles.
Set the user Access Desktop preferences.
Application definitions are a predefined set of instructions to describe application parameters, store responses and prepare responses for job execution.
