Add Altair One
Add and connect to Altair One server to submit and monitor jobs.
- Open the Windows system tray.
Double-click the Access Desktop icon
Click
Select Clusters.
A Clusters dialog box is displayed.
Select Altair One from the drop-down list.
Figure 1. Adding a Cluster
Enter a Cluster Display Name.
Note: You can use alphanumeric characters for a cluster display name.
Enter the Altair One URL https://www.altairone.com.
Figure 2. Connect to Altair One Server
Click Add.
A new web browser is launched and authenticates the user using the OpenID Connect (OIDC) and provides an authenticate code.
Figure 3. OIDC Authentication to Altair One
- Click Next.
Enter your Altair One login credentials.
Figure 4. Altair One Credentials
Click Verify.
The device is connected and activated.
Figure 5. Successful Login to Altair One
Close the browser. Return to the Access Desktop application; the
cluster is added, and a green check mark is displayed next to the cluster
name.
Figure 6. HTTPS Cluster Registered to Altair One
