Build specific search for a file type, combine multiple search values by selecting correct operators (=, Like, or
Is) and values (file name, file extension, metadata).
The updates made to your shared file will be available for you
automatically.
Share a file or folder with the following fixed roles:
Owner: User can execute, view, read, update, download
it to you local system, mark it as favorite, share it a another user, and
delete the shared files.
Editor: User can execute the file, view, read,
update, download it to you local system, and mark it as favorite.
Viewer: User can view, read, download files to you
local system, and also mark it as favorite.
You can always add or remove roles from a fixed role as necessary, however
this creates a Custom role.
The list of users and teams and their roles are
displayed in the Shared tab:
Click from your Favorite Apps on the home
page.
The Files tab is displayed.
Choose one of the following options:
Hover over a file or folder, click > Share.
Select the file or folder, click
Share on the Action Ribbon.
Right-click the file or folder and then click
Share.
The Share dialog box is displayed.Figure 1. Share File or Folder
To share with a user:
For Add User, begin entering the user name of a
user with whom you would like to share the file or folder.
A list of matching user names are displayed.
Figure 2. Matching Users
Select a user from the list.
Repeat the two previous steps to share the file or folder with
additional users.
To share with a team:
For Add Team, begin entering the name of the
team with whom you would like to share the file or folder.
A list of matches are displayed.
Figure 3. Matching Teams
Select a team from the list.
additional teams.
For Select Role, assign permissions to the file or
folder by choosing a role.
Editor: User can execute, read, update, download,
add as a favourite, and view details.
Owner: Provides full permissions for a user. This
includes Editor role and additionally, user can share and delete the file or
folder.
Viewer: User can read, view, download, and add it
as their favourite file or folder.
Custom: This role appears when you modify the
default permissions of the above default roles.
Click Submit.
The selected file or folder is shared and a notification is
displayed.
