Move a File or Folder
Move a file or folder using cut and paste options.
If you are moving the file in the same file path location then drag and drop action works to move a file or folder.
  1. Click from your Favorite Apps on the home page.
    The Files tab is displayed.
  2. Navigate to the file or folder.
  3. Choose one of the following options:
    • Hover over a file or folder, click > Cut.
    • Select the file or folder and click Cut on the Action Ribbon.
    • Right-click the file or folder and click Cut from the context menu.
  4. Navigate to the location where the file or folder to be moved.
  5. Choose one of the following options:
    • Click Paste on the Action Ribbon.
    • Right-click on the folder that you wish to move the file or a folder and select Paste.
    The file or folder is moved to the specified location.
