Create Indoor Walls in Urban Databases
Indoor walls and floors can be generated by the user manually by using the Create Interior feature. First, a building must be selected for which indoor walls should be created. By clicking the button , the following dialog appears on the screen:
Floors and walls can be generated separately to the selected building by clicking on Add Floors and Add Walls. Some parameters can be used to adjust the walls / floors as desired.
