In urban mode, WallMan can import a building from an
indoor-database. To do this, select the Import Indoor Database from the
Objects menu. WallMan shows a dialog to
select the file name of the indoor database. Only indoor databases which include at least one
shape can be used. Besides this, at least one floor level must be defined for the indoor
database. The building’s shape is copied to the clipboard from where it can be pasted to any
place in the urban database.
If the Display indoor walls of imported buildings setting are active,
the walls of the imported building are also displayed. The Properties
dialog of imported buildings shows the file name and location of the indoor database. It is
important that the imported file remains accessible for WallMan.
Note: In urban mode the shape of an imported building cannot be changed. However, imported
buildings may be moved around on the map.
