Node Tool
Use the Node tool to add new node objects to the database.
Once the
Node tool is selected, click with
the left mouse button where you want the node to appear. You can modify the Z-coordinate
of the node in the Object Properties dialog or by moving the node
in the side view window using the Edit tool. There are two types of nodes in TuMan:
![](../../../../../images/winprop/icons/tuman/button_node.png)
- Portal nodes
- Standard nodes
