2024
The TuMan tool enables you to generate and modify tunnel scenarios.
The WinProp Getting Started Guide contains step-by-step instructions on how to get started with WinProp.
The Altair installation directory contains a collection of examples that shows you WinProp concepts and essentials.
WinProp is a complete suite of tools in the domain of wireless propagation and radio network planning. With applications ranging from satellite to terrestrial, from rural via urban to indoor radio links, WinProp’s innovative wave propagation models combine accuracy with short computation time.
View the typical workflows when working with propagation simulations in specific scenarios, how to add a network planning to a propagation simulation, include a receiver pattern, set up a time-variant scenario, include multiple-input multiple-output (MIMO) at both the base station and the mobile station, connectivity analysis of sensor networks and optimization.
The WallMan component offers a convenient facility to generate and edit vector building databases.
TuMan can be launched via the command line, open a project and export a tunnel file.
Use the Line tool to draw a straight line.
Use the Arc tool to create a circular arc.
Use the circle tool to create a circle.
Use the break tool to break a segment out of a line object.
Use the Trim tool to shorten a line.
Use the Stretch tool to lengthen a line.
Assign segments to cross-section segment groups.
The cross-section of the tunnel tube and all vehicle areas are defined by their outline geometry.
In the edit mode, you can mark objects by clicking on the object using the left mouse button.
This tool is helpful when you need to navigate quickly through a database.
The Zoom Window tool enables you to select a rectangular area of the screen and zoom into a view of that area.
Objects can be marked with the Edit tool. Marked objects are displayed in red color. You can move, cut, copy or delete marked objects.
View the default shortcut keys available for TuMan for faster and easier operation.
Use AMan to generate, edit and analyze a single antenna. Superimpose multiple antennas radiating similar signals to determine the actual antenna pattern while taking into consideration the local environment.
The ProMan component includes wave propagation models for different scenarios and network planning simulators for various air interfaces.
WinProp includes empirical and semi-empirical models (calibration with measurements possible), rigorous 3D ray-tracing models as well as the unique dominant path model (DPM).
In WinProp various air interfaces and applications are pre-defined: broadcasting, cellular, wireless access, WiFi, sensor networks, ICNIRP and EM compliance.
The WinProp utilities consist of the Launcher utility and the Updater.
