Setting the Path Environment Variable
The executable for the WinProp API example requires libraries located in the %FEKO_HOME%\bin folder. Set the Path environment variable to point to these libraries.
- In Microsoft Windows, view the environment variables.
- Edit the Path environment variable and add %FEKO_HOME%\bin.
