Using the Microsoft Visual Studio Project to Compile the Executable
After CMake was used to generate the Microsoft Visual Studio project with all dependencies (linked libraries), build the project to create an executable.
The WinProp Getting Started Guide contains step-by-step instructions on how to get started with WinProp.
The Altair installation directory contains a collection of examples that shows you WinProp concepts and essentials.
WinProp is a complete suite of tools in the domain of wireless propagation and radio network planning. With applications ranging from satellite to terrestrial, from rural via urban to indoor radio links, WinProp’s innovative wave propagation models combine accuracy with short computation time.
View the typical workflows when working with propagation simulations in specific scenarios, how to add a network planning to a propagation simulation, include a receiver pattern, set up a time-variant scenario, include multiple-input multiple-output (MIMO) at both the base station and the mobile station, connectivity analysis of sensor networks and optimization.
The WallMan component offers a convenient facility to generate and edit vector building databases.
The TuMan tool enables you to generate and modify tunnel scenarios.
Use AMan to generate, edit and analyze a single antenna. Superimpose multiple antennas radiating similar signals to determine the actual antenna pattern while taking into consideration the local environment.
The ProMan component includes wave propagation models for different scenarios and network planning simulators for various air interfaces.
WinProp includes empirical and semi-empirical models (calibration with measurements possible), rigorous 3D ray-tracing models as well as the unique dominant path model (DPM).
In WinProp various air interfaces and applications are pre-defined: broadcasting, cellular, wireless access, WiFi, sensor networks, ICNIRP and EM compliance.
The OptMan component allows the automatic optimization of orientations of antennas in cellular networks to achieve various targets.
The CoMan component allows the simulation of the reliability and connectivity in wireless mesh / sensor networks.
The WinProp utilities consist of the Launcher utility and the Updater.
The WinProp API enables you to run WinProp simulations from within other software.
The WinProp application programming interface (API) enables flexible integration into other software tools or post-processing tools.
The programming language that is integrated with WinProp is C/C++. The application programming interface (API), allows you to control WinProp from an external program.
A number of small examples is available that illustrates how to use the WinProp API.
Before starting with the WinProp API examples, confirm that the minimum requirements are met.
To run a WinProp API example using Microsoft Windows is a four-step process.
CMake is an open-source, cross-platform tool that allows you to build and package software. It requires CMakelists.txt to generate build files.
The executable for the WinProp API example requires libraries located in the %FEKO_HOME%\bin folder. Set the Path environment variable to point to these libraries.
Run the example executable and view the simulation results.
Run a WinProp API example using Linux.
