Altair WinProp  2022.3 Documentation
2022.3
  1. Home
  2. Appendix
  3. Application Programming Interface (API)
    The WinProp API enables you to run WinProp simulations from within other software.
  4. Application Programming Interface (API)
  • Release Notes
  • Get Started
  • Examples
  • Introduction to WinProp
  • Typical Workflow in WinProp
  • WallMan
  • TuMan
  • AMan
  • ProMan
  • Methods
  • Main Applications
  • Optimization (OptMan)
  • Connectivity Manager (CoMan)
  • WinProp Utilities
  • Appendix
Index
2022.3
  • Release Notes
  • Get Started
    The WinProp Getting Started Guide contains step-by-step instructions on how to get started with WinProp.
  • Examples
    The Altair installation directory contains a collection of examples that shows you WinProp concepts and essentials.
    WinProp is a complete suite of tools in the domain of wireless propagation and radio network planning. With applications ranging from satellite to terrestrial, from rural via urban to indoor radio links, WinProp’s innovative wave propagation models combine accuracy with short computation time.
    View the typical workflows when working with propagation simulations in specific scenarios, how to add a network planning to a propagation simulation, include a receiver pattern, set up a time-variant scenario, include multiple-input multiple-output (MIMO) at both the base station and the mobile station, connectivity analysis of sensor networks and optimization.
  • WallMan
    The WallMan component offers a convenient facility to generate and edit vector building databases.
  • TuMan
    The TuMan tool enables you to generate and modify tunnel scenarios.
  • AMan
    Use AMan to generate, edit and analyze a single antenna. Superimpose multiple antennas radiating similar signals to determine the actual antenna pattern while taking into consideration the local environment.
  • ProMan
    The ProMan component includes wave propagation models for different scenarios and network planning simulators for various air interfaces.
  • Methods
    WinProp includes empirical and semi-empirical models (calibration with measurements possible), rigorous 3D ray-tracing models as well as the unique dominant path model (DPM).
  • Main Applications
    In WinProp various air interfaces and applications are pre-defined: broadcasting, cellular, wireless access, WiFi, sensor networks, ICNIRP and EM compliance.
    The OptMan component allows the automatic optimization of orientations of antennas in cellular networks to achieve various targets.
    The CoMan component allows the simulation of the reliability and connectivity in wireless mesh / sensor networks.
  • WinProp Utilities
    The WinProp utilities consist of the Launcher utility and the Updater.
  • Appendix
    • Application Programming Interface (API)
      • Scripts and Application Programming Interface (API)
        The WinProp application programming interface (API) enables flexible integration into other software tools or post-processing tools.
        • WinProp Database Conversion Interface
        • WinProp Wave Propagation Interface
        • Mobile Station Postprocessing
        • WinProp Network Planning Interface
        • Examples
        • WinProp_FMCW_Radar
        • Beam Generation
        • Beam type defines
        • File name defines
        • Additional callback defines
        • Error codes
        • Ellipsoid coordinate systems
        • Data Structures
2022.3
  1. Home
  2. Appendix
  • Release Notes
  • Get Started
  • Examples
  • WallMan
  • TuMan
  • AMan
  • ProMan
  • Methods
  • Main Applications
  • WinProp Utilities
  • Appendix
Index
  • Examples
  • ../../../../../topics/winprop/user_guide/appendix/api_auto_generated/struct_win_prop___f_m_c_w___para.htm
  • Beam Generation
  • Beam type defines
  • File name defines
  • Error codes
  • Data Structures
