Load Patterns From a File
Loading a pattern from a file is possible using the menu
.The file extensions of the 3D antenna patterns are:
Extension | Meaning | File Format Description |
.apb | Antenna pattern binary | not published |
.apa | Antenna pattern ASCII | See ASCII File Format for 3D Patterns. |
.ffe | Antenna pattern ASCII | See the Feko User Guide for more information1. |
1 View the
appendix in the Feko User Guide - .
