Define the initialization and finalization scripts, and properties for a
model.
Initialization Script
An initialization script provides a means for you to define OML variables and functions
for a simulation.
On top of the main diagram context, the software applies an initialization script, which is
yet another OML script that is executed at the beginning of the simulation process. The main
purpose of this script is to define the variables or functions that are required throughout
the model during a simulation.
Define Initialization Variables and Functions
Create a script with the OML variables and functions, such as the simulation final
time, that you want to be available for a simulation .
From the ribbon, select the the Model Initialization and
Properties tool:
The Model dialog opens.
Select the Initialization tab.
In the OML editor, enter the initialization
information for your model. You can include any valid OML command such as a
variable definition or function definition/execution.
Alternatively, if you want to load an existing initialization file, select
and navigate to the .oml script you want to
load.
Finalization Script
A finalization script provides a means for you to define OML commands that are to be
executed at the end of a simulation.
The finalization script lets you define OML commands that are to be automatically
executed when a simulation ends, such as plotting results or saving your data to a
specified location.
Note that the Finalization Script is executed when the simulation ends (reaches the final
time), or is stopped. It is not executed if the simulation is paused.
Define a Finalization Script
Enter the OML commands that you want to be automatically executed at the end of a
simulation.
From the ribbon, select the Model Initialization and
Properties tool:
Select the Finalization tab.
In the OML editor, enter the required OML
commands.
Alternatively, if you have an existing OML script that you want to load,
select and
navigate to the file.
