Interactive rendering modes are display modes that render your scene in real time, so you can interactively apply materials,
modify the environment, and change the camera position.
Distant light and sunlight are similar. You can change the intensity and size of a distant light, whereas sunlight
is calculated based on the position of the sun. Both emit light from so far away that when the rays arrive
at the object, they are parallel. As the result, surfaces with the same orientation receive the same quantity of light
regardless of their distance from the light source.
