2025.1
Adjust the materials, environment, and properties of objects in the scene to create a photorealistic image.
The Render Library contains preset and saved custom materials, environments, and models.
Discover new features and enhancements.
New to Inspire Studio? Learn the basics here.
Start using Inspire Studio with our interactive tutorials.
Create and edit a 2D sketch curve. A sketch curve is any "wire" entity such as a line, rectangle, circle, or arc.
Create and edit 3D curves by extending, rebuilding, intersecting, splitting, and projecting the shapes.
Create and edit 3D surfaces and solids by creating primitives or editing existing curves and surfaces.
Create polygonal surfaces that can easily be converted into NURBS surfaces.
Create new objects by manipulating and modifying source objects.
Quickly modify objects that are not a part of Construction History.
Deform one or more objects with respect to an axis.
Analyze curves and surfaces, import simulation data, or access the Design Table and Variable Manager.
Dimension a line, edge, bounding box, angle, and radius/diameter in order to create objects which must fit predefined dimensions.
Create detailed 2D drawings of the selected parts of a complex 3D model from multiple perspectives.
An overview of the typical rendering process.
A list of supported operating systems and minimum requirements for hardware and memory.
The Assets folder includes a default set of images, textures, materials, models, and environments that are used for rendering. Custom user-created materials and environments are also saved in the Assets folder, in the User subfolder. You can install the full Altair and continue to install updates when the online library is updated.
Interactive rendering modes are display modes that render your scene in real time, so you can interactively apply materials, modify the environment, and change the camera position.
Configure materials, the environment, lights, labels, the camera position, and the rendering settings.
The material library contains preset materials, as well as any custom materials you've saved. Understand the material library's structure so you can more easily find materials.
Import Thea materials into the Render Library.
You can choose from a variety of preset materials. If you can't find exactly what you want, you can choose something similar and modify it. You can also reuse a custom material that you have previously saved.
Save a custom material to the library so you can reuse it later.
You can choose from a variety of preset environments. If you can't find exactly what you want, you can choose something similar and modify it. You can also reuse a custom environment that you have previously saved.
Create a final rendered image. Learn how to adjust the rendering settings and change rendering engines.
In Inspire Studio you can animate an object or group and the camera. There are two methods of animation: key frame animation and path animation.
Create a draw die in Inspire Studio that you can export to Inspire Form to perform a stamping simulation.
You can use C++ and Python to add custom operations and file formats.
Learn keyboard shortcuts and mouse controls for common operations.
Inspire Studio supports 3Dconnexion's SpaceMouse.
