Interactive rendering modes are display modes that render your scene in real time, so you can interactively apply materials,
modify the environment, and change the camera position.
Modify the background, lighting, and shadows. A default global environment is included in Inspire Studio to place your model in a 3D context for rendering, but you can also customize the background image. Customize the
illumination, reflection, and background.
A label is a special type of texture that allows you to layer an image over an existing material. It is useful for
applying logos or bar codes to objects in your scene.
By adding cameras to your scene and customizing their position, angle, rendering image resolution, and rendering
image quality, you can view and render your models from multiple perspectives and create a more distinctive
scene.
Configure materials, the environment, lights, labels, the camera position, and the
rendering settings.
Create a Material
Create, modify, apply, save, and organize materials.
Modify the Environment
Modify the background, lighting, and shadows. A default global environment is included in Inspire Studio to place your model in a 3D context for rendering, but you can also customize the background image. Customize the illumination, reflection, and background.
Add Lights
Add, reposition, and edit lights for the scene.
Apply, Edit, and Position Labels
A label is a special type of texture that allows you to layer an image over an existing material. It is useful for applying logos or bar codes to objects in your scene.
Add and Edit a Camera By adding cameras to your scene and customizing their position, angle, rendering image resolution, and rendering image quality, you can view and render your models from multiple perspectives and create a more distinctive scene.
