Apply an Environment from the Render Library
You can choose from a variety of preset environments. If you can't find exactly what you want, you can choose something similar and modify it. You can also reuse a custom environment that you have previously saved.
  1. On the ribbon, select the Rendering tool.
    The Render Library is displayed.
  2. Select the Environments tab.
  3. Double-click an environment.
    The environment is applied to the scene.
