Render is the
faster option, allowing you to process the image in the application without the overhead of
loading Darkroom. You then have the option to send the image to Darkroom for processing or
save the image.
First,
you need to do the following:
- Open or create a model with materials applied.
- Define the rendering settings.
Do one of the following:
To |
Do this |
Render the current view |
- Press Ctrl+R.
- On the Rendering tab, click
the Render icon.
![](../../../images/gui/studio/ribbon/ribbonRenderingCurrentView-80.png)
Render selected objects |
- Select the objects you'd like to render.
- Press I to isolate the
selected objects. Isolating an object zooms in and
temporarily hides all other objects.
the Render icon.
- Press I again to un-isolate
the selected objects.
The Render Image window is displayed.
![](../../../images/figures/studio/render_image.png)
- To the bottom left of the current rendering, the status is displayed,
including information about the rendering engine, number of samples,
remaining time, and elapsed time.
- At the top right of the window, the scale is displayed.
- Optional:
To manage rendering, you can do the following:
Table 1. Render Image Options
To |
Do this |
Resume rendering |
Click Pause/Resume rendering.
![](../../../images/figures/studio/render_play.png)
Pause rendering |
![](../../../images/figures/studio/render_pause.png)
Save Image |
Click Save Image .
![](../../../images/figures/studio/render_save.png)
Continue rendering in Darkroom |
Click Continue rendering in
Darkroom.
![](../../../images/figures/studio/render_continuedr.png)
Save image to Darkroom |
Click Save image to Darkroom.
![](../../../images/figures/studio/render_savedr.png)
You can manage the stored renderings and perform
post-processing.
