Defeature
Fills holes and cutouts in the selected flange die part.
- On the ribbon, click the Die Design tab.
In the Flange Die section of the ribbon, click the New
icon.
Select Defeature.
The guide bar appears. - Select the Flange Part you would like to defeature.
Choose from the following selection methods:
- Tangent Selection: When you click an edge, all tangent edges are automatically selected.
- Chain Selection: When you click an edge, all connected edges are automatically selected.
- Single Selection: When you click an edge, only one edge is selected at a time.
Select the edges of the part you would like to defeature.
To Do this Close an opening in a surface - Select one or more edges where there is an opening
in the design.Note: If the opening in the design is made of multiple edges, make sure to select all of them.
- Right-click and mouse through the check mark to
exit, or double-right-click.
The surface will close.
Sharpen an edge - Select an edge you would like to make sharp in the
model.
The edge will sharpen.
Make a straight edge curved - Select a straight edge, or an edge that forms a
pointed corner with another edge.
The edge will curve where it connects to the adjacent edge.
in the design.
